  • Posted by 2 years ago. There are 4 posts. The latest reply is from KBS Coatings.
  1. Can Rustseal flex enough to work OK on coil springs without cracking :roll: ?
  2. Sure, that's one of the many benefits of RustSeal. Epoxies and powdercoating will crack when flexed...RustSeal will not. Just be sure to prep surface properly for good adhesion.
    What type of vehicle are you working on?
    http://www.kbs-coatings.com
  3. Hello, Thanks for the answer. I have a 1941 Dodge that I am restoring, and am going to use the Rustseal system on the frame, front suspension parts, and floorboards. I have just started to use some of it on the frame, and it looks great so far. Thanks :D
  4. Please let us know if you have any additional questions.
