Tags
  1. I have used your products on metal - great stuff! Now I need a paint to apply to wood to provide a very durable waterproof coating. Will be exposed to high humidity and moisture - not water as such. Do you a recommendation. Thanks for your help.
  2. Same product...RustSeal. It will seal the moisture out and prevent mold and/or mildew. Just make sure the wood is dry before applying. Since the wood is porous, it will stick great.What type of wood application are you using it on?
