RP27G8
Member
Posted 2 years ago #
I recently sprayed some RustSeal I bought. I stirred it for at least 15 minutes and still there were a lot of solids left in the bottom. Is there a better way to mix this stuff? Should I store the can upside down? I know it says not to shake but stirring alone didn't seem to get the job totally done. Any advice will be greatly appreciated! I will have before/after pics to post in about a week!
KBS Jim
KBS Coatings
What color RustSeal are you using? Is there a batch # on the bottom of the can?
RP27G8
Member
Jim,
I was using the gray and when I opened the can it was totally separated with all the solids on the bottom. I stirred it for at least 15 minutes and probably closer to 20. The number on the top of the can is 4405 and the number on the bottom is 105801. I didn't see anything on the can that described a particular lot number.
When I sprayed the product it flowed out great and the final finish looks great. I am just concerned about the stirring process and the amount of solids left int he bottom.
Thanks!
