  1. I have a gas tank with pin hole around the weld at the gas gauge. Will the 3 step process seal these holes? The tank has already been painted. Tank is 18 years old and doesn't appear to have alot of rust on the part of the tank I can see. Local dealers are unsure if product will fix the holes. Help?
  2. If they are indeed "pin" sized holes, then yes the three step kit will work great! Any larger, you'd need to use the NuMetal putty first.Here's the instructions: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html
