  1. Hello, I'm nearly ready to order the KBS I need to seal the concrete garage floor. I plan to use Fusion SEP primer as well. I need an idea as to how many square feet per gallon I can expect to get from both Rust Seal and Fusion. I plan to apply three coats of Rust Seal. The concrete is quite smooth. Thank you. Everything I have done with your products so far has come out great.
  2. Lee, How have you been?Here's the link to our KBS for Concrete: http://www.kbs-coatings.com/KBS-RustSeal--Seal-Concrete_ep_74-1.html
    I don't think it's necessary to use the Fusion in this application. I would however, thin the first coat of RustSeal maybe up to 20% to allow the coating to really penetrate and adhere to that concrete of yours.
