  • Posted by 1 year ago. There are 3 posts. The latest reply is from .
  1. I am restoring a car and I am going to use KBS rust seal to paint some of the floor area. Obviously I want to give the paint the best change of sticking by following your reccommendations. However I don't really want to spraying water around inside the car to rinse rust blast, or your cleaner off as there is no way to getting all the nooks, crannies and box sections to dry it all out, this will lead to further rust in areas I can't get to. Will the rust seal adheare well enough if I have wire wheeled all the surface rust off and then keyed it with sand paper and finally cleaned as best I can with deteregent de-greaser and a cloth?
  2. Sure, just be sure to wipe down these areas with a damp/wet rag to remove the residue from the cleaner. You can use a torch to dry the nooks and crannies as water can reside in these areas as you stated. You'll see the steam releasing from areas you thought were dry.
  3. Thanks, just got the paint from your UK guy so i'll give it a go this week and see how I get on.
