  • Posted by slo 10 months ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. if i am going to use one of these kits would there be a prob if i go iside a thread? or will it help like teflon etc? if coat something that is already bolted together wil there be a problem n bolting the part? or will it break off like a paint or anything else...
    thanks
  2. You will NOT want to paint the inside of your threads. RustSeal will end up being 5-6 mils thickness.If it is bolted together, RustSeal will help to keep it permanently sealed together. You will not want to do that if you plan on taking the bolt off easily.Complete RustSeal instructions can be found here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html
