JWPOORE
Member
Posted 10 months ago #
I have a fiberglass top on my truck that is white on the inside, can Rust Seal in the white color be used on it to protect and freshen it up or would paint specifically for fiberglass be a better option/method.
KBS Coatings
KBS Coatings
Yes. You can do that.Please remember that the RustSeal Off-White is Off-White and is NOT a brilliant white. Also, if the RustSeal is going to be consistently exposed to UV rays, you will want to topcoat it.You can find complete instructions here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html
JWPOORE
Member
I think that would be fine. This would be on the inside of the top (interior area) so an off white or not so bright would be preferred. Being that it is the inside of the top and not exposed to the outside elements, would it be fairly UV/fade resistant without the need of a topcoat?
KBS Coatings
KBS Coatings
If it will not be hit by UV Rays, it will remain Off-White.
