  • Posted by rbranstetter 10 months ago. There are 3 posts. The latest reply is from rbranstetter.
  1. I think I applied under humidity that was slightly too high. I have very small bubbles in the finish and I would like to find out what I need to do here.
    Hoping I do not have to strip and start over. this was just the first coat.
    I plan on putting 3 coats down, then followed by Blacktop.
    Also, how long MAX should I wait between coats of rustseal? I have limited time to work on this project and will probably be giving coats every night until done.
    Thanks
    Ryan
  2. Ryan --
    You can give the RustSeal a sand to get rid of the bubbles and then go over it with another coat of RustSeal.
    Doing coats every night should be fine for you.
    Please let us know if you have any other questions.
  3. Thanks very much
