  • Posted by jonny walker 10 months ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. I want to strip my Gas Tank. I think there is kreem in there. How do I do this with the KBS Strip?
  2. Pour some stripper into tank and carefully rotate tank to allow contact with all sides. It may take multiple applications of stripper to finish the job completely. Old Sealer may come loose in big chunks or small pieces so use a long tweezers-type tool to help remove it from the tank. After stripping is complete, rinse tank generously with water and proceed with the KBS 3-Step System for Fuel Tank Preparation & Sealing. (NOTE: When stripping a Fiberglass Tank, surface contact with the stripping agent should be kept to a minimum to avoid the attack & weakening of the fiberglass resin.)
    You can find complete Strip Instructions here: http://www.kbs-coatings.com/kbs-strip-info.html
