  • Posted by aw_kc 10 months ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. i have several snow plows. i always have issues with rust, and i wanted to coat the blades of the plows in a KBS coating. i was wondering what would be the best KBS products to use.
    thanks
  2. Are the plows sandblasted or going to be sandblasted? If they will be sandblasted, you can apply 2-3 coats of RustSeal and then an opaque top coat.
    If they will not be sandblasted, you will want to use the 3 Step System of AquaKlean, RustBlast and RustSeal. And then top coat with an opaque top coat.
    Two kits that should work for you:
    Frame Coater Kit (will cover 50 sq. ft.): http://www.kbs-coatings.com/KBS-Frame-Coater-Kit_p_26.html
    All-In-One Chassis Kit (will cover 50 sq. ft. and contains a Black top coat): http://www.kbs-coatings.com/KBS-All-In-One-Chassis-Kit_p_36.html
    Please let us know if you have additional questions.
