  • Posted by platboy 8 months ago. There are 2 posts. The latest reply is from KBS Jim.
Tags
  1. Hi I just used Rust blast for the firest time in some freshly sandblasted car patch panels. I followed the instructions to the letter, with the exception of Aquaclean as it says it isn't required on freshly blasted metal. Now I have some areas that have the white residue, some areas that look as they did before (although a darker shade of grey) and some areas of brown which I am guessing is flash rust. It does in fact look exactly like the POR 15 example on the website comparison. Is it better to agitate the rustbast with a bristle brush or similar (I just painted it on with a paint brush). I am not comfortable simply painting the Rust seal over this flash rust, as it is worse than when I started. Any ideas? Cheers, James.
  2. James, as the directions state, neither AquaKlean nor RustBlast is needed after sandblasting. The sandblasting manages to clean and abrade the surface for excellent RustSeal adhesion. You can reapply the RustBlast now keeping it wet for 15 minutes or longer as desired, and you can use something such as a scotch-brite pad to scour the surface. Immediately rinse with water, and immediately dry the surface with a clean dry cloth and/or compressed air. Drying the surface off helps to keep the moisture from just sitting on the substrate and the beginning of flash rust. Then let the surface air dry very well before painting.
