  • Posted by dkf1998 7 months ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. I am going to paint an old 12' aluminum boat, how will the Rust Seal work on this application? will it help seal the rivets that are a little leaky?
    Thanks
  2. Will it be sandblasted?
    If so, you can apply 3 coats or more of the RustSeal and then topcoat if necessary (if it will be consistently exposed to UV rays).
    If not, you will want to use the complete KBS 3 Step System (AquaKlean, RustBlast & RustSeal). And then topcoat if necessary (if it will be consistently exposed to UV rays).
    It should seal your leaky rickets as long as they are not too bad.
