  • Posted by 47merc 9 months ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. I have a vintage car engine with an aluminium crankcase and sump and I have had these pressure cleaned to as new condition. I want to paint the inside of these to seal them. Will any of your products do this job and be ok in the oil and heat?
  2. Yes. Use the KBS 3 Step System. It is fine with that oil and heat up to 600 degrees. Make sure you get the surface really, really clean with the AquaKlean (the 1st step in the 3 Step System).
