  • Posted by mallorybl 8 months ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. I intend to cover the underside of my newly installed galvanized floorboards w/ Herculiner. The rest of the undercarriage will be coated w/ KBS rust seal then the herculiner. Should I use the rust seal over the floorboards as well? I intend to sandblast the rest of the undercarriage. Should I do the same to "etch" the galvanized steel? Or, how would I get the best results?
  2. "Should I use the rust seal over the floorboards as well?"
    Yes. That would be best.
    "Should I do the same to "etch" the galvanized steel? Or, how would I get the best results? "
    Yes. That would also be best.
