  • Posted by nadephil 1 year ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. My refrigerator is filled with rust spots on the inside of the door where the plastic seal goes around. The seal is also filled with rust. Will rustseal be able to cover the rust or just coat it so no more rust will emerge?
  2. You can use the System Sampler: http://www.kbs-coatings.com/KBS-System-Sampler-Kit_p_23.html
    Make sure it is bone dry before the RustSeal Step. Also, make sure it is completely dry before you put it back in service.
