  • Posted by ronny 8 months ago. There are 4 posts. The latest reply is from KBS Coatings.
Tags
  1. Hi,
    Can numetal be used as filler to smooth out welds or inperfections on heads or extractors. Will it be affected by high temperatures or any type of coating system such as ceramic.
    Thanks
  2. What is the maximum temperature that you need the NuMetal to withstand?
  3. Hi,
    Sorry for the delay. The max temp would be 700deg/c.
    If it was possible, once the filler was cured would it be able to withstand sandblasting process.
    Thanks.
  4. NuMetal will withstands temps up to 300°F (150°C). It does not appear that NuMetal would work for your High Temperature application.
