Can I use the tank sealer with an aluminium tank and do I just follow the same instructions as for a steel tank? Will the tank sealer react to methanol fuel?
Yes. It will work on an Aluminum Tank. The Instructions are the same.
You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html
