  • Posted by bambookoo 4 months ago. There are 2 posts. The latest reply is from KBS Coatings.
Tags
  1. Hi
    i am in the process of coating a whole car with your products such as rust seal and top coat
    i would just like to know about the grounding points on the vehicle
    i can sand the areas down but i would think that those areas will rust
    could you please advise me on how to tackle this
    thanks
  2. Just grind off the RustSeal, make your connections. The beauty of the RustSeal is it will not allow the rust to creep beyond the area.
    You can also apply some dielectric grease to the area.
