  • Posted by 1 year ago. There are 2 posts. The latest reply is from KBS Coatings.
  1. HELLO. JUST A QUICK ?? I NEED TO CLEAN AND SEAL THE INSIDE OF TWO CYCLE TANKS IF I PURCHASED THE LARGE CYCLE KIT , WOULD I BE ABLE TO DO ONE TANK NOW AND THE OTHER ONE AT A LATER DATE ? WOULD I BE ABLE TO RESEAL THIS PRODUCT TANK SIZES ARE 3.2 GAL & 4.2 GAL OUTSIDE OF THE SMALL TANK IS IN MINT COND OTHER ONE IS FAIR COND ..........
  2. Yes that would work. Before dividing the Pint of Tank Sealer, make sure you stir it well first. Also, recap the can right away and use plastic wrap to avoid permanently sealing the lid. I would try & use the Tank Sealer in a reasonable amount of time. The shelf life of an opened can be prolonged by storing it in a cool dry place.Also, you do understand not to try & save any drained sealer as it has already started the curing process. Tank Sealer: http://www.kbs-coatings.com/Tank-Sealers_c_7-1-0.html
    Tank Sealer Instructions: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html
