  • Posted by bambookoo 2 months ago. There are 6 posts. The latest reply is from KBS Coatings.
No tags yet.
  1. hi
    i was removing some paint today and removed some of the rustseal on another panel
    i found that the panel under the paint was all rusted again
    should i remove the rust seal and start again
    or should i not be worried?
    i know that rust seal will treat some of the rust
  2. How were you removing the paint? How did you apply the RustSeal?
  3. when i was doing that section i was only using a wire brush on a drill
    i aplied the rust seal with a brush
    now i am using i think it is nylon brushes on the dril
    so it is removing the rust more this time
  4. You will want to wire wheel it all down to the bare metal and then use the KBS 3 Step System of AquaKlean, RustBlast and RustSeal.
  5. ohh damn
    i need to wire wheel most of the car down now to find out what areas are rusted
    the whole inside of the car has been coated aswell
    i waited till the rust started to go a bit white in colour
    so i thought the rust seal would work over it
    oh well
    thanks for the help though
  6. Your welcome. Please let us know if we can help you in any other way.
