  • Posted by Stan Carr 5 months ago. There are 2 posts. The latest reply is from KBS Coatings.
Tags
  1. Want to use aqua klean and rust blast /seal on classic car wheels that have wooden spokes and split rims. Will products harm wood and tires?
  2. No. If you follow the directions, you should not have any trouble with wooden spokes of split rims.
