  • Posted by royluck 1 month ago. There are 6 posts. The latest reply is from KBS Coatings.
Tags
  1. Hi, have you got anything to treat the outside of the tank, small areas on top of the tank have bubbled.
    Thanks.
  2. Are you talking about the existing paint on the outside of the tank has bubbled?
    Did you seal the inside of the tank?
  3. Tank has been sealed, stripped & sealed again, tank was then repainted, base coat & 2 pack clear & it has bubbled through the paint, one tiny spot in the bottom corner of the tank & several bubbles at the top.
    I have carefully cut the paint back in these areas & want to treat with something that won't react to fuel & then repaint.
    Thanks for your help. Roy............
  4. Yes. Coat that area with the 3 Step System (AquaKlean, RustBlast and RustSeal).
  5. So is the motorcycle tank kit the smallest amount I can get?
  6. Yes. That is the smallest kit that we offer.
