It sounds like that tank had a previous sealer that is failing. That old sealer needs to stripped using KBS Strip.
You can find KBS Strip here: http://www.kbs-coatings.com/kbs-strip.html
You can find KBS Strip Instructions here: http://www.kbs-coatings.com/kbs-strip-info.html
After stripping, follow the KBS system for sealing that tank. Avoid applying the sealer to the plastic area as much as possible.
