  • Posted by FrankV 1 year ago. There are 2 posts. The latest reply is from KBS Jim.
  1. Can I use a flattening base in the BlackTop to create the flatness that I am after???
    Will the flattening base affect the Blacktop??
  2. You can try it, however BlackTop is a moisture cured coating and any moisture content in the flattening agent may cause the BlackTop to cure too quickly. I would try a test sample first to see if it already is flat enough for you.
