I doing a frame up restore on a 1977 CJ5. The frame and bottom of tub have some light surface rust, but no body cancer. I have already used a 3500 PSI pressure washer on all components and all road grime and loose particles are now gone. I plan on hitting all surfaces with a wire not wheel in a 4" grinder. Do I really need to use the aqua wash if the pressure washer took off all oil and grease. I planned on just using the etching material and top coat. I also plan on doing the entire undercarriage, diffs, trans, springs etc.. as well as the bottom of the tub and engine compartment. I was going to buy a gallon jug, once this product is exposed to air does it all have to be used at one time or can I close it up and use the rest later.
Thanks for the help. I am so glad I found your site I was just about to spend over double on Por15.
Thanks
Kevin
