Bobb
Member
Posted 1 year ago #
Hello, First off I would like to thank the people from KBS for making such a great product. THANK YOU! My frame and chassis turned out so good some people think I had it done at a body shop.
Floor Pans!!!
I will soon be buying the trunk and floor pan kit, However I also need something to cover the exterior bottom. I thought about useing some type of spray on bed liner under the body. Do you offer something to cover the exterior bottom of the car?
Also, My ride is a 1978 Chevy Monte Carlo, Will one trunk and floor pan kit be enough?
KBS Jim
KBS Coatings
Posted 1 year ago #
Thanks for the kind words.
You can use RustSeal alone on the underside of the floor, or apply an undercoating over the RustSeal. That way you'd have the rust protection and some sound deadening and/or heat insulation. There are a couple of products (Lizardskin & Second Skin) out now that are water-based that can be applied over RustSeal.
Figure a kit will cover approx. 50 square feet with two coat protection. Be best to just measure the area(s) you wish to cover. There is plenty of prep in the kit, you just may need to order an additional pint or quart of RustSeal.
