  • Posted by 2 years ago. There are 4 posts. The latest reply is from KBS Jim.
  1. Will KBS Gold fuel tank sealer be affected by any of the additives in standard gasoline or any of the fuel injection cleaners on the market?
  2. No. It will stand up just fine to those additives.
  3. I have read on several forums that the ethanol currently found in fuel may dissolve tank coatings. This could lead to carb gumming. Any problems noted with KBS coatings?
    Steve
  4. The current 15% ethanol blends have proven to be no problem. The 85% or E85 blends have not been around long enough to be substantially tested. It is presently being tested.
