No tags yet.
  1. I have a 1970 Norton motorcycle with a fiberglass tank. The current fuel additives in gasoline is melting the tanks resulting in a gummy residue in the fuel system. Will your product seal the interior of the tank to prevent this problem? If your product will prevent this, what prep is required on a fiberglass tank?
  2. Our 3 step cycle tank kit will work great for you. Choose the 5 or 12 gallon depending on your size tank.
    Step #1 is cleaning with AquaKlean to thoroughly remove gum, varnish & fuel residue.
    Step #2 is a quick coating with RustBlast to leave a zinc phosphate coating for good tank sealer adhesion.
    Step #3 is Gold Standard Tank Sealer. Fiberglass is very porous & our tank sealer will seep into and interlock with it to cure into a permanent, nonporous, fuel & additive impervious coating.
    Our complete instructions are posted here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html
