Anonymous
Posted 2 years ago #
Hi, I'm trying to restore a motorcycle tank that has had gas in it for
23 years! I have use POR-15 kits before, but I really like your prices better.
I've already done some cleaning and I was thinking the next step
would be using a solution of water and muriatic acid to clean the inside
before using your motorcycle tank kit. Do you think I should use the
muriatic acid wash, then use your kit - Or should I skip the muriatic acid
wash and use just your kit?
KBS Coatings
KBS Coatings
Either way would be fine. I would just use the kit.
You can find the Gas Tank Sealing Kits here:
http://www.kbs-coatings.com/Tank-Sealers_c_7-1-0.htmlYou can find complete instructions for the tank sealer kits here:
http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.htmlAlso, check out our how to section here:
http://www.kbs-coatings.com/Howie-How-To_ep_44-1.html
