  1. Do you make a coating to seal a rusting oil pan? The pan would be degreased, blasted and cleaned first.
    The coating could go on either side maybe?
  2. Most people use the Gold Standard Tank Sealer or the RustSeal to seal their oil pans.
    Here would be your process:
    1) It needs to be cleaned really well with a water-based cleaner like our AquaKlean.
    2) Blast it.
    3) Blow off the loose dust.
    4) Apply 2-3 coats of Gold Standard Tank Sealer or RustSeal.
