I have a 1973 Ford Bronco which I have been making repairs in for the last year. At a couple different times in the past I have used both POR-15, and Rustseal. I am eventually going to probably use a bedliner like Line-X over everything. I am considering purchasing a EVO-T spray gun to spray a nice even coat over both the POR-15 and last years Rustseal. There are a few spots where I stll need to cover better. Am I making a mistake putting a second coating over previously coated areas? Everything is fully cured now. Would I have to lightly scuff it up with a green scotchbrite pad? Should I just leave it alone, and not topcoat it? I am not looking to paint it, but protect it, and when it goes to be Line-X'd, they will want to scuff it then. Would it be better that they are scuffing a "Topcoat" vs. the Rustseal? Thanks.
I would scuff the coating that you have now (that is fully cured) with a scotch brite pad. Then spray another coat of RustSeal thinning it 5% to get it out of the gun nicely.
